Welll long story short.
I just got a Philips 20PF5320F... 20" wide screen. And we already had a Yamada DVD-Mi220X
A HDMI Dvd player.
So I bought a HDMI-DVI cable off ebay so I could connect the Dvd player to the DVI port on the TV, to get a better picture.
And, for some reason it doesn't work.
Anyone help me out?
Thanks in advance.
Originally Posted by Stu_
I have ordered a DVD recorder; & plan to do what you are doing. Pls post on this forum any solution to your problem. It would help me.
Best wishes,Best regards,
Sam Osborne -
This PDF lists all the supported formats for the TV.
http://www.p4c.philips.com/files/2/20pf5320f_01/20pf5320f_01_pss_eng.pdf
Try DVD player at 720x576p and 1280x720p. Use whichever looks best to you. -
Originally Posted by edDV
Thanks, but my DVD recorder is not Philips but Panasonic DMR-ES25S. Guess, my question should have been this: Are any problems anticipated if one uses a HDMI to DVI-D cable to reap the benefits of HDMI upconversion feature of this recorder? My LCD HansG monitor has a DVI-D interface, in addition to a VGA interface.Best regards,
Sam Osborne -
edDV was not saying you had a Phillips player he was refering to your Phillips TV. He is saying that link shows that your TV set supports PAL and Secam standards. IOWs it appears you are in the US but bought a PAL TV Set? If you can set DVD player output to 720p or 1080i it looks like it might work.
Try to be more specific with model numbers. You said you had a Yamada DVD-Mi220X DVD player. That is also a PAL model.
The Panasonic DMR-ES25S appears to be an NTSC model.
Oh, you aren't Stu_ -
Dear edDV & TBoneit:
Appreciate your replies. Yes, the Panasonic DMR-ES25S DVD recorder is NTSC model.
My 1st question is: Are any problems anticipated if one uses a HDMI to DVI-D cable to reap the benefits of HDMI upconversion feature of this recorder? My LCD HansG monitor has a DVI-D interface, but no HDMI.
My 2nd question is: Will a NTSC DVD recorder, like the Panasonic DMR-ES25S DVD recorder, accept composite video input in PAL format? The PAL format video signal can be fed to the DVD recorder from a separate PAL VCR's "video out" connection. The 2nd question is very important to me!
Shall appreciate answers from anyone.Best regards,
Sam Osborne -
Are you talking about a computer monitor? It is unlikely to work unless the manual lists 720p support.
VCR's are NTSC, PAL or Multi-standard. Check the spec.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Connecting DVR (HDMI) to DVD recorder (non HDMI), on HDTV...
By SOHkat in forum DVD & Blu-ray RecordersReplies: 2Last Post: 19th Oct 2010, 13:50 -
dvd player hdmi to computer monitor with hdmi
By Kibble in forum DVD & Blu-ray PlayersReplies: 5Last Post: 10th Nov 2008, 12:35 -
Connecting DVD player through HDMI: 2 Problems
By Markaveli in forum DVD & Blu-ray PlayersReplies: 10Last Post: 22nd Aug 2008, 06:40 -
TEVION 8000 / 8001 HDMI DVD PLAYER problems with picture freezing....
By denny91 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Oct 2007, 09:56 -
Tevion 8001 HDMI DVD player - disc sticking/freezing problems.
By denny91 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Oct 2007, 09:50
