Is there a majr difference between XVID Mpeg 4 files compard to Quicktime Mpeg 4 files? I am asking because when i burn a Quicktime Mpeg 4 file to disc, my Liteon and Philips dvd plays will not play it back. But when I burn a XVID mpeg 4 file, they playback fine.
Results 1 to 12 of 12
What containers are you using? .mov for quicktime? and .avi for xvid?
What kind of quicktime mpeg4 are you using? mpeg4 sp/asp or mpeg4 avc/h264?
And if you have a .mov with mpeg4 you can try change it to an avi with mp4cam2avi. -
XviD is MPEG4 ASP. And QuickTime is H.264/AVC.
Both standards are MPEG4, but not compatible with each other, unless otherwise noted by the playback device. -
Quicktime is MPEG4-SP and h.264.
An MPEG4-SP encoded file should play fine on your player (as it's a more constrained subset of what you currently can play), but the h.264 won't.
Scott -
Yes, what he said. As well, most stand alone players are usually only compatible with MPEG-SP, since DivX and XivD use that standard...
...and Quicktime MPEG4-SP in an MP4 container should work in players that support MP4 containers. (How many?)
Scott -
Thanks for the replies. So , to cap it off I will use DIVX and XVID codes, but I cannot use mpeg 4s with h264.
I can use XVID with h263.
Here is one more question,
What AVI codecs are the ones that usually don't work with DIVX/AVI/XVID capable dvd players? Some AVI files I have that are regualr avis will not play or look really weird on both players. -
Just a guess/hunch...
Codecs that should work:
DivX 4, 5, 6, Xvid, 3ivX, Mpeg4 SP & ASP from other sources (avoid too many of the "enhancements") incl. possibly 3GP/iPod/PSP, Mpeg2, Mpeg1.
Codecs thatshouldn't work:
Uncompressed, Losslessly compressed (HuffYUV, Lagarith), DV, MJPEG, WMV, Cinepak, Indeo, many many others. h.264 also, unless specifically stating that it IS supported.
Depends:
DivX 3, MS Mpeg 4
(edited after celtic_druid's post) -
DivX 4 was just SP MPEG-4 and DivX 3 = MS MPEG-4 V3, which whilst not actually MPEG-4, I have never heard of a SAP that couldn't handle it (some of the earlier models I think did have some issues though).
When it comes to avi one problem could be the fourCC. Whilst technically players should be able to handle any MPEG-4 Part 2 video stream (as long as it doesn't use features not supported) they only support a limited set of 4cc's. Still most tools when you remux mp4 to avi will set the fourCC to XVID, DIVX, etc. rather than mp4v. -
You can always change the fourcc though. AVIFrate, AVI Fourcc Changer, others.
MPEG-4 ~ what's the difference?
By kr236rk in forum Video Streaming DownloadingReplies: 15Last Post: 3rd Feb 2016, 08:31 -
mp4 xvid vs H264 mpeg-4 avc quality difference
By johnharlin in forum Video ConversionReplies: 2Last Post: 8th Apr 2012, 07:38 -
Difference between MPEG-1 or MPEG-2?
By PHNeedsHelp in forum Video ConversionReplies: 3Last Post: 2nd Dec 2009, 16:42 -
Time difference between VOB and MPEG
By sambat in forum Newbie / General discussionsReplies: 6Last Post: 18th Aug 2008, 15:06 -
Quicktime parse error converting mpeg-1 muxed to DV or mpeg 4
By jglass in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2008, 20:51
