I have a 16:9 video file that needs to display properly on a 4:3 TV. The original video file is 544x304 according to ffmpegx. How do I know what aspect ratio to use and what numbers for letterboxing to avoid having the video vertically stretched when displaying on the 4:3 TV?
You may have to experiment a bit here. I would use MPEG Streamclip for something that requires that I manually letterbox the video. If you do some math, 544 > 640 would mean that the 304 comes up to about 357. I believe ffmpegX will require a multiple of 16 so use 352. As you want to get to 480, that means padding the top and bottom by 128 pixels; 64 - top, 64 - bottom. That should work.
In other words: Forget about aspect ratio and use whatever numbers will mathematically work for you.
I admit this is not an area I am knowledgeable so I am following your lead. I also just learned that TiVo requires the final video to be one of the following "720 x 480, 704 x 480 (D1), 544 x 480 (3/4 D1), 480 x 480 (2/3 D1), or 352 x 480 (1/2 D1)". So with that in mind what Video size should I choose and what padding would i need?
I took a look at MPEG Streamclip but after loading up the XviD all the needed export to mpeg options in the file menu were greyed out. So lets just stick with ffmpegx
From your last post, it appears your TIVO likes MPEG2 (you probably don't have the MPEG2 QT component from Apple installed). I am not sure whether ffmpegX requires this for mpeg2 output or not; I have it but I've always had it so I can't give you a definitive answer on this.
Use the DVD mencoder setting. I would do the math as if you're going to 640x480 (so make your height comply with the example I gave you in my previous post), but then set 720 as the width and encode it as mpeg2 for DVD but uncheck the "author" checkbox as you don't need the VIDEO_TS folder.
Be sure the "Letterbox" checkbox in the Filters tab is checked. Click the Encode button and let us know what happens.
HowTo add permanent Letterboxed subtitles to video w/ Virtualdub, SRTtoSSA
By KneeRow in forum SubtitleReplies: 20Last Post: 13th Feb 2013, 14:05 -
Why is flv file off youtube letterboxed when the YT video isn't?
By brassplyer in forum Video Streaming DownloadingReplies: 1Last Post: 5th Jan 2011, 15:21 -
Converting 16x9 video to 4x3 letterboxed in Sorenson Squeeze
By pjbarbour in forum Video ConversionReplies: 0Last Post: 10th Mar 2010, 10:49 -
How to convert 4:3 letterboxed DVD to 16:9 video file?
By abw1987 in forum Newbie / General discussionsReplies: 6Last Post: 19th Sep 2009, 12:43 -
Software to convert a letterboxed video back to true widescreen?
By gastrof in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2009, 16:39
