    Mar 2007
    Version: SVCD2DVD 2.1
    Build: 2.1.2474.30185
    Please find error below when authoring titleset, gets to 50%.
    Any help? Thanks in advance.
    Type: System.NullReferenceException
    Source: SVCD2DVD
    Message: Object reference not set to an instance of an object.
    InnerException:
    StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.AuthorDVD(xc76 139390a97debb xd2637df501625a82, x81974c36d7fdf1e1 xb4ee5c1758e9e983, Int32 xdc4f66b5011a3c9d, String[] x738d70b20493db82, Boolean x6b20cb17e8070d92, Boolean x3c21da9f928aac10)
    at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc 498()
    at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
  2. Could be a problem with the source file. Can you post your log file?
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
    Mar 2007
    Have tried different source files still same error.
    Where do I get the log file from?
    Driving me nuts now.
  4. Um...in the 'LOGS' folder where the program is installed...
    Dwight
    - Herm Albright
