    Mar 2007
    Australia
    i have a dual layer dvd Filled with 4 Movies
    The main Menu lets u select which movie u want to watch
    Each movie has its own menu eg. select chapters, play movies, special features
    I want to get each movie and its menus on to a DVD-5 speratly without the main one.
    Is there a way?
    TY
  2. Hi-
    Is there a way?
    Yeah, it's easy. Open the DVD in VobBlanker and blank out 3 of the movies, leaving just one. Process everything. Then do the same thing for the other 3 movies on the DVD. At that point you'll have 4 different DVDs, each beginning with the menu that has you choose which movie to play. Then open each of the 4 new movies on DVD in PGCEdit and trace past the opening menu to the menu where you really want to start. Save and Test. Here's a guide about blanking using VobBlanker:
    http://dvdguides.netgeekhosting.com/guides/blanking/
    And here's a guide about how to skip past that opening menu to get to the "real" menu for each DVD:
    http://download.videohelp.com/r0lZ/pgcedit/third_party/blutach/How_to_use_PgcEdit_new_macro.htm
    Mar 2007
    Australia
    Um Is there a way to do this of the four movies
    DVD 1:
    Main Menu for movie selection
    2 Movies each with menus
    DVD 2:
    Oct 2006
    Canada
    There is also DVDRemake which will do what you want all in one. It is not free, but well worth the $30US.
  5. Um Is there a way to do this of the four movies
    Why didn't you say that the first time? It's even easier. Follow my instructions and the guide from my earlier post about using VobBlanker, but this time do it twice, instead of 4 times, each time blanking out 2 of the movies. When done you'll have the original menu to choose from 4 movies, but only 2 movies on each DVD. Then use MenuEdit or PGCEdit (I use PGCEdit) to hide the 2 buttons so you can no longer choose the 2 missing movies on each DVD. Either that or edit that menu to completely remove all traces of the missing movies.
