3GP_Converter fails before trandcoding complete itunes authuring (NicMP4Box.exe)? I thing it because the vista new file structuring or something?
pls HELP![]()
Results 1 to 11 of 11
does anybody else that use vista have this problem with that converter?
You may be out of luck. Vista does use different file structuring. There's a list of Vista compatible programs here: http://www.iexbeta.com/wiki/index.php/Windows_Vista_Software_Compatibility_List
You could try SUPER. It does seem to work with Vista and may be able to do those type of conversions. Otherwise, it may take a while before the applications catch up with the new OS. You could try the software's internet site and see if they have any info. Also, there may be a forum for your program that may help.
And welcome to our forums.
It's probably becauase my hack uses MY documents i think let me look at it. e-mail or PM me the log that gives the error and i'll try to fix it.
After dealing with a few programs that Vista didn't like, I also found, 'Run as administrator' and 'XP SP2 compatibility mode' solved many of them. Right click on the program before you install and you will see the first option. The second is the 'Program Compatibility Wizard'. Find it by typing that name in a 'Help and Support' window.
Neither option will help much with poorly written or old programs, but it does solve some issues with programs that run OK in XP SP2. -
yeah that was the site the hack was on originally. Is it working for you now?
Yeah, it works on vista but that freak'in "User Acces Control" pops up at the end of the encoding process because of the NicMP4Box.exe, other then that it's straight.
Ipod Not Recognised In Windows Vista
By Teac23 in forum Portable VideoReplies: 2Last Post: 18th Apr 2010, 20:56 -
Control Vista Media Center using iPhone/iPod Touch
By Seel in forum Media Center PC / MediaCentersReplies: 0Last Post: 5th Dec 2009, 07:02 -
Vista hack for this annoyance...........
By SIRCOOKS in forum ComputerReplies: 4Last Post: 17th Mar 2009, 23:16 -
Aah! My DVX100B isn't detected in Vista... is there a fix?
By Tobuscus in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 13th Oct 2007, 13:45 -
iPod H.264 640X480 3gp_converter hack
By ssj2_goha in forum Portable VideoReplies: 87Last Post: 12th Oct 2007, 20:01
