I'm using a Shure SM58 microphone and I want to be able to increase the volume in comes into the computer. When I try to increase the volume using adacity or something, it puts in noise. What hardware can I use to increase the volume of my mic?
Would an ART Tube MP Microphone Preamp help increase my microphone volume? Anything else you would recommend around $50?
I'm mostly just doing like podcast /talking.
m-audio audio buddy
whats wrong with any $2 microphones for *podcasting*?
Your podcast sound quality is probably heavily compressed anyways.
Find the specs for your card's mic input impedance, then buy appropiate mic, and I'm sure you don't need any excellent sound card nor any pro brand microphone for some podcast's low bitrate high compression MP3 or AAC sound -
So you've got a low-to high impedence adapter/transformer to convert the XLR connection to 1/8" mini, correct ?
Some software volume controls have a checkbox to add +20dB of boost to the mic input signal.
Also, are you 100% sure you're using MIC in and NOT line in ?
How to increase Video Sound Levels on AVI. Files or Mpeg
By c_a_konopka in forum EditingReplies: 14Last Post: 27th Jun 2012, 20:48 -
How to increase Video Sound Levels on AVI Files or wmv files
By lovebeing in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2010, 08:25 -
Need help with audio recording software that adjusts microphone input
By jimcornetet in forum AudioReplies: 3Last Post: 24th Apr 2010, 01:01 -
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 11:46 -
Proc amp? Fix levels at input to Canpus ADVC110
By 2Bdecided in forum Capturing and VCRReplies: 16Last Post: 3rd Jun 2008, 10:31
