Im trying to merge some .srt subtitles with an Xvid avi file. Im using mencoder dev-CVS-060307-04:23-4.0.1, that were from ffmpegXbinaries20060307
The command I'm using isThe problem is, no matter what settings i use for -font or using -sub-font-scale the subtitles all look the same, and their all too small. Using the same subtitle settings in mplayer give good sized subtitles, but when I go through mencoder I get the same small ones everytime.Code:./mencoder target.avi -alang jpn -ovc xvid -xvidencopts bitrate=900:chroma_opt:vhq=4:bvhq=1:quant_type=mpeg -oac mp3lame -sub subs.srt -font ~/.mplayer/font/font-arial-24-iso-8859-1/font.desc -subpos 90 -o filename.avi
The same thing happens in ffmpegX, when i go to add the subtitles and hit preview they show up how I want them to, but after encoding them they go back to being small again.
Is there someway I can force it to use a different size other then the default? Or is there another tool I can use for Mac, either natively or from darwinports or fink. Id rather not have to go through autogk in Parallels since its a big pain.
Awesome, I dont know why I never thought of that, I just thought I was doing something wrong, not that it was ignoring font options cause it was loading a default.
I always assumed that the default font would be in ~/.mplayer and since there wasnt anything there I thought it was a command issue, but after looking a bit its in /usr/local/share/mplayer instead, replaced the tiny default font with the right size one and its good now.
Thanks.
Best subtitle font?
By flickerx in forum SubtitleReplies: 21Last Post: 14th Feb 2019, 16:36 -
Subtitle font color
By stem300 in forum SubtitleReplies: 3Last Post: 12th Dec 2011, 13:30 -
Problem with font size of added subtitle in MKV file and freezing pic
By tindrli in forum SubtitleReplies: 0Last Post: 24th Mar 2010, 11:47 -
bigger and better font when I create AVI with mencoder
By Cazz in forum DVD RippingReplies: 0Last Post: 16th Mar 2010, 17:17 -
What subtitle font is this?
By jonghyunchung in forum SubtitleReplies: 6Last Post: 16th Feb 2010, 15:59
