I thinking of making a movie by filming Star Wars Galaxies while playing. I am using fraps to film. But a editing program im thinking of getting (Final Cut Express HD) can't read the .AVI files that fraps produces. Is there another video screen capture program that u use, or a way to convert the .AVI into different files without losing resolution? Or a way to change the options on the Fraps program to produce a different .AVI or use a different compressor?
Results 1 to 20 of 20
why not just rip the DVD, try dvdshrink or Ripit4me
dvddecrypter
there are plenty of options, for this -
dreach is talking about the video game, not the film.Originally Posted by theewizardHe's a liar and a murderer, and I say that with all due respect.
oops... I guess he has the correct Idea then,
I thought it was a FAN film -
Fraps uses a custom codec called FPS1. It is installed together with Fraps, and should allow you to edit the video in all kinds of programs. It's possible however, that Final Cut HD doesn't like the codec, or, the resolution of your capture.
Before you go try all kinds of different editing programs, think about the resolution your final product/movie should have. If the resolution you are capturing in now is higher then what the final movie is going to be, maybe it's wise to use another resolution for your captures.
Try to stick with existing video resolutions and frame-rates if possible. Fraps can produce high resolution captures, with a high frame-rate, which in turn are a pain to edit (uses lots of resources).
If you stick with the resolution you are using now, I bet a lot of people here can advise you what software to use for high resolution captures.
i tried it, and not even 30 seconds of recording, was 996megabites in size
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 08:17 -
Video screen capture
By cottage in forum Capturing and VCRReplies: 5Last Post: 9th Dec 2010, 16:37 -
I need tips for Screen Capture (Video) Software
By FallenAngelII in forum Capturing and VCRReplies: 5Last Post: 17th Oct 2010, 23:22 -
Best video/screen capture software
By latr0486 in forum Video Streaming DownloadingReplies: 2Last Post: 27th May 2009, 17:58 -
How do I do a Screen Capture from a U-Tube video
By bryankendall in forum Newbie / General discussionsReplies: 2Last Post: 1st Dec 2008, 17:34
