When I created a dvd movie from an avi file, the audio track was terrible, with hisses and cracks. How could I demux the audio track from the avi file, which is fine, and apply it to the VOB's?
I have VirtualDubMod but I wouldn't know how to use it in this case.
If your file is a AVI type, it may have MP3 audio, which is unacceptable for DVDs. I use VirtualDub Mod to save out the audio as a WAV format file. Load the video then go to 'Streams>Stream list. Right click on the audio track and select 'Full processing mode'. Then click 'Save WAV'. After the audio is saved, you can close VDM.
From there, if you need to do some audio filtering, you could load the WAV into Audacity and see if you can clean it up. Then save it out as a WAV again. I use ffmpeggui at that point to convert the WAV to AC3. Then all you have to do is mux it back with your MPEG-2 video, author and burn.
VDM, Audacity and ffmpeggui are all freeware programs and work very well. Lots of guides for VirtualDub, and Audacity works just like a word processor, so it's not hard to learn. ffmpeggui is pretty much automatic, just use the defaults.
Adding additional audio track to vob file
By jtoo1 in forum Authoring (DVD)Replies: 4Last Post: 6th Aug 2011, 03:19 -
Changing VOB file audio track order
By mmdmmd in forum EditingReplies: 1Last Post: 4th Oct 2009, 15:12 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 12:16 -
Changing/Removing an audio track from a .vob
By TheWeasel in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jul 2007, 08:31 -
Cannot hear the correct audio track from ripped .vob files
By ronhammond71 in forum DVD RippingReplies: 0Last Post: 26th May 2007, 15:25
