Hi, hope someone can help.
In premier 6.5, there was a feature that enabled you to have clips flying onto the main screen from all sorts of angles and allowing it to zoom away, spin etc. I remember that you could get to it from right clicking a timeline clip. This feature seems to have disapearred from 1.5, or at least I cant find it, does anyone know how to do it in 1.5 or where I can do it?
Regards
West
Why the hell do you want to do those 1980s video toaster effects for! (just joking
They're there. Just look in the effects menu:
lol.
it wasnt the preconfigured effects that I wanted to use. I found what I was after. It is under effects controls window and then motion effect, then yuo can totally customize it.
cheers for your help anyway.
Missing main video screen
By Greatminty in forum Authoring (DVD)Replies: 2Last Post: 15th Jan 2012, 17:04 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 19:27 -
Capturing Images on the PC screen while on U Tube
By bryankendall in forum ComputerReplies: 4Last Post: 24th Dec 2009, 13:29 -
Shakey images in LCD screen of Sony Handycam
By J Lynn in forum Newbie / General discussionsReplies: 3Last Post: 16th Mar 2009, 18:48 -
How to full backup (no encoding) BR main movie, main audio with subtitles ?
By meico1234 in forum Blu-ray RippingReplies: 2Last Post: 2nd Feb 2009, 03:37
