I'm want to cut an one hour length DVD folder into 4 pieces:
so i loaded it on PgcDemux:
and for some reason the demuxed video stream duration it created was only 29 Minutes!!!
i also tryed to play the M2V file in mplayerc but i got the same results!
what did i do wrong?
Thanks !!!
Probably nothing. Only very few programs can show the duration of an elementary stream correctly. The most 'secure' are mpeg2schnitt or cuttermaran (these count each frame). Faster is dgindex (part of the dgmpegdec package), and even more fast is ChapEditGFD. Please note, that ChapEditGFD assumes clean timecodes (usually ok after demux with pgcdemux) and shows the duration as ntsc non drop frame timecode, even if it is drop frame (this will be fixed in the next version). For PAL the duration is correct.
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
borax, thank you man!!!!
you saved me!!!
i was crackin my head over here!!!!!
thanX!
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 17:23 -
Demuxing Problem
By jpmccusa in forum Authoring (DVD)Replies: 8Last Post: 18th Mar 2010, 20:10 -
Demuxing DL problem
By calanda in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2010, 00:52 -
Problem with authoring DVD folder
By nanook in forum ffmpegX general discussionReplies: 5Last Post: 20th Nov 2009, 03:40 -
Problem with Demuxing
By Elvish Hero in forum Authoring (DVD)Replies: 3Last Post: 17th Jan 2008, 04:56
