I'm attempting to use ffmpegX to convert a large (~8GB) movie file with uncompressed audio down to a smaller (~2GB) file. Every time I start ffmpegX, the install dialog pops up requesting that I point it at the files for mplayer/mencoder, despite the fact that I have done this repeatedly. When I actually try to transcode the movie file, the output I get is a ~200MB file that's totally unplayable, and for all I know, contains the output of /dev/random.
I like the way this software looks, but the functionality leaves a HELL of a lot to be desired. Is there something I can do to get this software to: A) stop asking me to point it at the same .zip file over and over for "installation" purposes, and B) actually work?
I suppose your source movie is DVD; but what is your target format?Originally Posted by nacho_hat
...meaning the installation of the binaries didn't go well.Originally Posted by nacho_hat
Possibly it failed because of the binaries not being correctly installed (it depends...) What is the filename extension of this output file? What does ffmpegX say in the Summary tab, if you drop the output file back on the main window? It should try to read its characteristics, which could be helpful diagnostics.Originally Posted by nacho_hat
It asks you to point to binaries extracted from the zip archive, not the zip file itself.Originally Posted by nacho_hat
Ahah, I did not know it was looking for the extracted contents of the .zip file.
The source file is actually just that, a file, a very large, only lightly compressed AVI. I am trying to compress it down to a more reasonable amount of diskspace.
I will retry the transcode after I have installed the items from the zip file and post the results
Bump.
Nobody knows that answer to this? Maybe it's just time to delete ffmpegX and go looking for another solution.
ffmpegx.com installation
By a.fritz in forum Video ConversionReplies: 1Last Post: 16th Jan 2011, 23:38 -
installation of ffmpegX (##mkdir: /usr/local/lib: File exists)
By carlos028 in forum ffmpegX general discussionReplies: 1Last Post: 19th Dec 2010, 20:57 -
Installation of ffmpegx
By Docdawh? in forum ffmpegX general discussionReplies: 12Last Post: 19th Nov 2010, 00:13 -
ffmpegX Installation problems....
By maiof06 in forum ffmpegX general discussionReplies: 1Last Post: 31st Aug 2008, 01:32 -
ffmpegX installation
By barry3333 in forum ffmpegX general discussionReplies: 38Last Post: 25th Feb 2008, 19:43
