Actually i have tried to use Premiere Pro 1.5 and import the a Divx files created from a PMP device, (I have installed K-Lite Codec Pack and Divx codec), it works normal, but now the problem is after i upgrade to Premiere Pro 2.0, i import the same files but the audio seems not detected by Premiere, is there any plugin required? I use Gspot to check the clip audio codec, it shows using "Microsoft IMA ADPCM", how to make Premiere 2.0 recognized the audio? Pls give some advice, thx~
Results 1 to 1 of 1
Windows Movie Maker capture import to Premiere Pro
By burrenyoga in forum Capturing and VCRReplies: 5Last Post: 24th Aug 2010, 09:36 -
Adobe Premiere Pro CS4 Cannot Import .mp4 File
By spike32 in forum EditingReplies: 5Last Post: 19th Jan 2010, 08:15 -
Premiere Pro 1.5 cannot import DivX AVI
By Arjun_M in forum EditingReplies: 6Last Post: 10th Jun 2009, 09:00 -
Cant import AVI files into Adobe Premiere Pro 1.5 (again)
By Undead Sega in forum EditingReplies: 1Last Post: 13th Oct 2007, 20:35 -
Premiere Pro 1.5 Won't Import Any AVI? Zoiks!
By glowing_zebra in forum DVD RippingReplies: 1Last Post: 7th Jul 2007, 04:28
