Lately I have been trying to generate frame accurate cutlists by Comskip for automatic editing.
So I compared MPEG2CUT2, Videoredo, MPEG2VCR and VirtualdupMOD on their frame numbering and found they all act different.
When looking to the first frames of a recording, they do not even start with the same frame.
How is that possible?
How to generate automatic editing frame numbers when all the editors act differently?
I don't have a direct answer, but try Cuttermaran as well. Set Comskip to also demux automatically, then run -
Code:Comskip capture.mpg Cuttermaran.exe "E:\path to created by comskip\capture.cpf"
Code:Comskip.ini output_demux=1 output_cuttermaran=1
Will try but I want to be able to support videoredo because many people seem to use it.
How fast is cuttermaran in cutting and muxing? I have a slow PC. -
Most cutters will cut on the I-frame interval only.
Some will do frame-accurate cutting and re-encode the interval. Don't think any freeware does this.
Cutting captured files often results in audio synch issues. Results may vary depending on capture equipment.
Cuttermaran has worked well for me, also MPG2Cut.
Worst case scenario, the TRIM function in the Sonic MyDVD authoring package is able to correctly trim files that no other program will handle. I-frame only. -
Originally Posted by Nelson37"Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
This works really well. Turn off automatic demux, as the Xport.exe utility does more accurate demuxing.
Code:comskip capture.tp xport.exe capture.tp 1 1 1 ren bits0001.mpv capture.m2v ac3fix bits0001.mpa capture.mp2 Cuttermaran.exe "E:\path\to\capture.cpf" mplex -f 3 -b 1850 -r 25000 -o Capture_Clean.mpg capture_clean.m2v capture_clean.ac3
Help converting mpeg type video with correct frame rate
By DJX in forum Video ConversionReplies: 0Last Post: 9th Oct 2010, 18:24 -
Suggest a video editor for frame-by-frame editing
By ontherocks in forum Newbie / General discussionsReplies: 14Last Post: 24th Apr 2008, 09:36 -
What Video editor's can cut frame by frame?
By VEBouto in forum Newbie / General discussionsReplies: 19Last Post: 28th Oct 2007, 01:31 -
Correct Terminology for a menu frame that shows a clip from the movie
By gayclarke in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2007, 08:19 -
Best frame by frame editor?
By demonwarrior in forum Newbie / General discussionsReplies: 6Last Post: 30th Jun 2007, 05:38
