http://www.keohi.com/keohiHDTV/htpc/yxy/yxy.html
YXY is a free aspect ratio controller program that is used with Intervideo's WinDVD DVD Player. With YXY you can position the WinDVD window to precise locations on the screen, and save those locations for future use. The program should work with other software DVD players as well, or other applications such as software TV players. My primary testing has been done with WinDVD however.
The main benefit of this tool is if you have a front projection system, you can leave your projector memory set up for anamorphic sources (i.e. vertically squeezed.) When playing non-anamorphic DVD's you can simply size the window of the DVD player 33% taller than normal. It will then look like an anamorphic DVD to your projector. Similarly you can shrink a 4:3 shaped movie to take up the center portion of the 16:9 screen shape.
In addition the program can be used to save a variety of custom settings. The settings that I use handle:
1.66:1 movies that take the full height of the screen, but have small bars on the sides
1.37:1 full-screen material positioned to the left or to the right within the 16:9 anamorphic window, to avoid burning in the image
2.35:1 movies positioned at the top or bottom of the screen, to avoid burning in the image
Slightly expand the window of some underscanned movies
Reposition the window of some non-anamorphic letterboxed movies which have their subtitles beneath the image
Crop full-frame unmatted movies back to their correct aspect ratio. Instead of just taking a "slice out of the middle" I can take the top portion of the image for those movies that are shot with the common-top-line method, where most of the unmatting is done at the bottom.
Other program features include:
Resize the application window larger than the actual screen without requiring a virtual window program such as WinSpace.
Automatic blanking calculation (to hide the DVD player caption and borders) with custom overrides
Orbiting (move the window around on the screen in small increments to avoid screen burn-in)
Button repeat function for easy interactive screen positioning. Just hold the Moving and Sizing buttons down, and after a short delay, the action will repeat until the button is released.
Proportionally move the window up, down, left, and right; proportionally shrink or expand the window height and width, separately, or together
Command line startup options to select a particular setting
Global hotkey support for selecting settings. Works even when the YXY window is hidden or in the background.
Playlist feature lets you associate particular DVD's or other titles with a specific setting
When a DVD is inserted that is on the PlayList, automatically switch to the correct aspect ratio
When an unknown DVD is inserted, automatically add it to the PlayList using default settings
Ability to disable the PC Friendly DVD-ROM program from launching when loading a DVD.
Results 1 to 1 of 1
DVD aspect ratio & file size alters in video editing software
By Chrismar in forum Newbie / General discussionsReplies: 2Last Post: 21st Aug 2011, 08:48 -
Aspect ratio for stand-alone DivX/XviD players?
By Gew in forum RestorationReplies: 1Last Post: 9th Mar 2009, 14:52 -
Whats going on? miniDV, software, aspect ratio, dimensions
By vid83 in forum Newbie / General discussionsReplies: 2Last Post: 12th Dec 2008, 08:25 -
Aspect Ratio Chaos distorting 16:9 to 4:3 software
By lukes123 in forum Authoring (DVD)Replies: 4Last Post: 1st Apr 2008, 17:18 -
Video player with aspect ratio and brightness control
By silverwolf0 in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2007, 09:16
