well today when burning some files in Nero, I selected to start multi-session disc and made sure that finalize cd was not selected but after burning the cd and putting it back into the pc..surely enough, the cd was finalized....and only like 57.8MD of space was used and the rest was wasted.....Does nero give this problem with anyone else or is this a problem with my pc/burners ?
Here's the log of the burnWithout my name + serial number)
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/17/2002 9:20:56 AM
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 6:35:34 PM
Nero Version: 6.6.0.13
Internal Version: 6, 6, 0, 13c
Recorder: <SAMSUNG CD-R/RW SW-240B> Version: R403 - HA 1 TA 0 - 6.6.0.13
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <ZK6489L KQF354F >Version: 2.0B - HA 2 TA 0 - 6.6.0.13
Adapter driver: <vaxscsi> HA 2
=== Scsi-Device-Map ===
DiskPeripheral : ST380021A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : SAMSUNG CD-R/RW SW-240B atapi Port 1 ID 0 DMA: On
CdRomPeripheral : VOM-12E48X atapi Port 1 ID 1 DMA: On
CdRomPeripheral : ZK6489L KQF354F 2.0B vaxscsi Port 2 ID 0 DMA: Off
CdRomPeripheral : ZK6489L KQF354F 2.0B vaxscsi Port 2 ID 1 DMA: Off
=== CDRom-Device-Map ===
SAMSUNG CD-R/RW SW-240B D: CDRom0
VOM-12E48X E: CDRom1
ZK6489L KQF354F F: CDRom2
ZK6489L KQF354F G: CDRom3
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 510MB (523244kB)
Free physical memory: 68MB (69936kB)
Memory in use : 86 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
12.3.2007
CD-ROM (ISO)
10:08:25 AM #1 Text 0 File Isodoc.cpp, Line 6194
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
10:08:25 AM #2 Text 0 File Burncd.cpp, Line 2882
JustLink activated
10:08:25 AM #3 Text 0 File Reader.cpp, Line 127
Reader running
10:08:25 AM #4 Text 0 File Writer.cpp, Line 122
Writer SAMSUNG CD-R/RW SW-240B running
10:08:25 AM #5 ISO9660GEN -11 File geniso.cpp, Line 3293
First writeable address = 0 (0x00000000)
10:08:25 AM #6 Text 0 File Burncd.cpp, Line 3167
Turn on Track-At-Once, using CD-R/RW media
10:08:25 AM #7 Text 0 File DlgWaitCD.cpp, Line 260
Last possible write address on media: 359844 ( 79:59.69)
Last address to be written: 29647 ( 6:37.22)
10:08:25 AM #8 Text 0 File DlgWaitCD.cpp, Line 272
Write in overburning mode: NO (enabled: CD)
10:08:25 AM #9 Text 0 File DlgWaitCD.cpp, Line 2339
Recorder: SAMSUNG CD-R/RW SW-240B;
CDR code: 00 97 15 17; OSJ entry from: Ritek Co.
ATIP Data: ?
10:08:25 AM #10 Text 0 File DlgWaitCD.cpp, Line 438
>>> Protocol of DlgWaitCD activities: <<<
10:08:25 AM #11 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 29648 (29648) = #29648/6:35.23
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 29646 blocks [SAMSUNG CD-R/RW SW-240B]
10:08:25 AM #12 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [SAMSUNG CD-R/RW SW-240B] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 61026304, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
-150 | lead-in | 0 | 0x41 | 0x00
-150 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
29648 | lead-out | 1 | 0x41 | 0x00
10:08:25 AM #13 Text 0 File ThreadedTransferInterface.cpp, Line 1111
Removed 2 run-out blocks from end of track 1. Length: 29648 -> 29646.
10:08:25 AM #14 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
10:08:26 AM #15 Text 0 File Burncd.cpp, Line 4051
Cache writing successful.
10:08:26 AM #16 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
10:08:26 AM #17 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 16x (2,400 KB/s)
10:08:26 AM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
10:08:26 AM #19 Text 0 File Mmc.cpp, Line 21469
Set BUFE: JustLink -> ON , JustSpeed : ON
10:09:05 AM #20 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
10:09:10 AM #21 Text 0 File Mmc.cpp, Line 16119
<SAMSUNG CD-R/RW SW-240B > start Close Session
10:09:28 AM #22 Phase 37 File dlgbrnst.cpp, Line 1832
Burn process completed successfully at 16x (2,400 KB/s)
Existing drivers:
File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 8/17/2001 2:07:32 PM
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 7/17/2002 8:53:02 AM
File 'Drivers\PXHELP20.SYS': Ver=2.03.32a, size=20640 bytes, created 4/25/2005 3:03:00 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 8/3/2004 11:59:42 PM (Adapter driver for rec)
File 'Drivers\vaxscsi.sys': Ver=?.?.?.?, size=223128 bytes, created 8/11/2006 8:00:18 PM (Adapter driver for src)
Registry Keys:
HKLM\Software\CPUCooL (Power saving: CPUCooL)
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
I've never used multi-session myself. I find it is easier to use RW discs when you need to keep adding files.
Regardless, what did you use to check the disc? Have you tried burning more data to the disc?
From the log above, the disc does not appear to be finalized.Google is your Friend -
the cd reads as having 0MB free space...and in nero when trying to add more data files, it says to insert a cd with free space or when using the windows burning one...it says the same thing
Longevity of CDs and DVDs? Are my old CDs starting to lose it?
By garybeck in forum DVD & Blu-ray RecordersReplies: 15Last Post: 25th Jan 2013, 14:38 -
Nero works with CDs not with DVDs
By fiiido in forum DVD & Blu-ray WritersReplies: 13Last Post: 23rd May 2008, 04:44 -
Finalizing
By JaredKnight in forum Newbie / General discussionsReplies: 2Last Post: 30th Sep 2007, 08:53 -
how to finalizing a dvd+r ...
By jvlbr in forum Newbie / General discussionsReplies: 6Last Post: 6th Jul 2007, 22:29 -
Problem finalizing Playo DVDs
By bobbanks in forum MediaReplies: 3Last Post: 22nd May 2007, 11:18
