Results 1 to 17 of 17
    Mar 2007
    Pakistan
    I am from Pakistan and I have region free samsung's E138B with region 3 written on the back. I want to purchase some dvds from UK. I know UK's dvds are in PAL format. I am concerned if the player will be able to play the dvds or not. Is there any way I can check it before purchasing.
    It plays dvds purchased from the US.
    Haris
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    UK DVD is PAL. That your player is region free, doesn't say anything about if it will play PAL DVD or not. You can download a PAL DVD test image here:
    http://www.recordere.dk/indhold/templates/design.aspx?articleid=911&zoneid=3
    Just burn it to a DVD-R and try it out.
    /Mats
  3. Banned
    Freedonia
    If your US DVDs are region 1 DVDs then your player should be in region free mode and you should be able to play region 2 DVDs from the UK. I think that Pakistan uses PAL, so you shouldn't have any problems with that.
    Mar 2007
    Pakistan
    Mats: Could you please tell me how am I going to write this image. I have nero 7 so downloaded nero image?
    jman98: Pakistan has region 5 but my player has region 3 and NTSC written on the back. so this means that the player was imported from somewhere and then made region free.
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    I don't use Nero, so... But download the Nero image, Load it with File -> Open, then burn.
    Better is to download the ISO and burn it with ImgBurn
    /Mats
  6. Banned
    Freedonia
    Do NOT run Nero Express. Run Nero Burning ROM. Use File then use Open to open the image and you will be able to burn it.
    That's unfortunate that you bought a region 3 NTSC player. It's probably from Taiwan. You will have to burn the test image and see if it works or not. If your DVD player has a video output section that has 3 choices like this:
    PAL NTSC MULTI
    then you will probably OK to play PAL DVDs on this player.
  7. Member ntscuser's Avatar
    Mar 2003
    Care to elaborate as to why? I thought the basic functions in Nero Express and Nero Vision Express were identical to the full burning ROM?
  8. Banned
    Freedonia
    Because I don't know how or if it is even possible to burn images in Nero Express. I know how to do it in Nero Burning ROM. You do yourself no favors if you use Nero Express as it hides you from the more complex and more useful features of Nero. If it is possible to burn images in Nero Express, then yes, you can use that.
    Mar 2007
    Pakistan
    /Mats
    finally I tried this and my dvd player did show a screen with text in german i think. but remote's navigation keys didnt work.
    does this mean that my dvd player is able to play pal dvds?
  10. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Can't say for sure - but it sure sounds like it, unless the German text says "The player can't play this disc" or something to that effect.
    /Mats
    Mar 2007
    Pakistan
    /Mats
    there is quite alot of text in there.
  12. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Can you play it on your computer?
    If so - does it look like on your player?
    Can you take a screen dump of it, so I can see (and possibly translate)?
    /Mats
    Mar 2007
    Pakistan
    /Mats
    How do I take screen dump? I think Print Screen would not work here.
  14. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Most video players have a snap shot function. See the applications help file.
    /Mats
    Mar 2007
    Pakistan
    PFA screenshot. My dvd player shows same screen.
  16. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Looks fine - it says something (in Danish, not German ) about that it's a test for pixel errors, but if your player wouldn't have played PAL, you wouldn't have seen this on your TV using your standalone DVD player.
    /Mats
    Mar 2007
    Pakistan
    /Mats
    thanks alot Mats.
