Results 1 to 9 of 9
Take a look at this webpage, the section on "Overload" about 2/3 down the page.
http://www.doc.ic.ac.uk/~nd/surprise_96/journal/vol4/sab/report.html
Another possible result is known as wrap-around. This is where all out of range values are converted to the lowest value i.e. black. This can result in poor quality video and should be avoided if at all possible. See figure 6.5.
jagabo, I'm wondering if this has something to do with colorspace conversion?
(just guessing, I am trying to learn more about color spaces, color ranges, and their limitations )grannyGeek ~~
Antique Newbie -
Originally Posted by grannyGeek
You can also first convert the file to lossless AVI, then apply the effect to your new AVI file. That should help....
Originally Posted by Guiboche
cd090580
Hello! Please, could you try out MSU Smart Deblocking 0.8, and if the problem repeats - write to the support email that can be found at the bottom of MSU Smart Deblocking homepage.
Please, report any bugs and\or suggestions - let's make the filter better!
dv cassette deblocking
By noiz in forum RestorationReplies: 7Last Post: 16th May 2011, 18:13 -
MSU Smart Deblocker
By miggeth in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jun 2008, 07:26 -
Using MSU Smart Deblocking Filter...
By AshleyQuick in forum Newbie / General discussionsReplies: 4Last Post: 28th Apr 2008, 20:17 -
deblocking a video
By themaster1 in forum Video ConversionReplies: 3Last Post: 26th Feb 2008, 10:44 -
So far, VISTA has more holes than swiss cheese...
By ahhaa in forum ComputerReplies: 24Last Post: 13th Jun 2007, 19:24
