I haven't found a truly good one on the Mac, unfortunately. I've tried to use ffmpegx, but it's too frustrating. It has very serious sync problems on many sources (particularly when encoding from dvd), as well as numerous annoying nuisances such as reporting improper duration (if it says the source is 91 minutes long, don't believe it), choosing wrong aspect ratios/framerates, and not always "keeping elementary streams" even when that option is explicitly checked.
This is not to say that it never works well (sometimes it works great, in fact), but I've never been able to figure out ahead of time when it's going to have trouble, so I've wasted a lot of time doing failed encodes.
I now use the older (free) version of EazyVCD on the PC (yes, blasphemy, I know) to make (X)VCDs. I've never had any sync, framerate or aspect ratio problems with it, and it is extremely fast (not an apples-to-apples test, I know). You can also choose from among several speed/quality settings. It just works, which ffmpegx does not do with any consistency. The only deficiency of EazyVCD is the lack of subtitle support. In those cases, ffmpegx is the low-cost tool of choice.
The most reliable mac-based flow for making vcds is first to use a different tool to encode into high bitrate (say, 1.5-2Mb/s) divx/xvid. This takes care of the sync issues. Then use ffmpegx to encode into vcd/xvcd/kvcd/svcd. When starting from divx, ffmpegx tends not to exhibit the problems it has when starting from, say, dvd source material. The only drawback of this flow is slow speed because of the need to generate the intermediate divx file. But it lets you insert subtitles at the last step of the conversion, so if that capability is important to you, that's the most reliable VCD creation method I know of on the mac (using free or very inexpensive tools). -
MMT-EZ (freeware) will make many different types of vcds.
The download/info page is here:
http://www.angelfire.com/mac/rnc/ -
I agree with this sentiment as well. Since I run a Mac mini (Intel) at home, I grabbed an unused copy of Windows XP Pro from work, and installed the last freeware version of TMPGEnc.Originally Posted by tomlee59
VCD resolution and bitrate is perfectly fine for watching movies on a computer, so I use TMPGEnc to encode hours and hours of content to burn onto a dual layer DVD, and then play back in Apple DVD Player. -
TMPGEnc is a terrific tool; I wish that a version of it were available on the mac. EazyVCD uses TMPGEnc under the hood to do the heavy lifting, and the results are quite good. Being able to put more than 10 hours of videos on a single 4GB flash drive is a great thing for long trips. It's amazing how long a laptop battery will run things when it doesn't have to power up anything that spins.
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 09:13 -
Capturing VHS to Mac via Panasonic AG-1980 and ATI 650 USB Mac
By Stu187 in forum Capturing and VCRReplies: 3Last Post: 15th Aug 2010, 05:45 -
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 05:18 -
Future Mac Video encoder
By fatespawn in forum MacReplies: 14Last Post: 13th Dec 2008, 20:49 -
Mac AVCHD encoder
By bertoa in forum MacReplies: 3Last Post: 23rd Jun 2008, 08:16
