Ok I have a lot of MP3's with bad tags. I have gone in and manually
named the files in the <artist> - <song> format.
Is there any tag editor that will read the file name and fill in the
tag with the info I have in the filename?
Nickolas
The GodFather (according to its help file) has some support for converting filenames to tags. It's what I'd probably use, as it is what I have.
I use ID3-TagIT and it easily converts back and forth. It's freeware and very good IMO. Look in Tools section. If not there, Gooogle it. Good luck.
Wayne -
If you use Foobar2000 as a player, it can do it. Just set the wildcards and it will import from the filename. It can also tag from freedb2 for albums.
Use Mp3Tag
http://www.mp3tag.de/en/index.html
Best app when it comes to tagging (to my knowledge). Supports a lot filetypes, not just Mp3. Many built in converters like tag->filename and vice versa. Supports online inquiry of databases like freedb. It's free and it's great.
Regards -
All great ideas....for my wife that is. She is an MP3 maniac...
Any free ID3 or music tag editor/tool that can convert character set.
By csh in forum AudioReplies: 1Last Post: 17th Jun 2012, 12:09 -
My MP3 ID3 Tags are being changed?
By Denvers Dawgs in forum ComputerReplies: 2Last Post: 31st Mar 2011, 18:08 -
MP3 DirectCut and id3 tags
By olyteddy in forum AudioReplies: 4Last Post: 17th Mar 2009, 21:42 -
Help me replace Musicmatch Jukebox - ID3 look up service
By Jeff234 in forum AudioReplies: 0Last Post: 23rd Aug 2007, 03:20 -
Possible ID3 Tag Problem
By Graham099 in forum Authoring (DVD)Replies: 0Last Post: 11th Jul 2007, 07:45
