I recorded some audio of almost 2 hours in length that occupy about 27M of mp3 space. I believe the format was at 32K byte. When I bring it in to Sound Forge 8 and simply Save As it balloons to 44M. A similar thing happens in Audacity. If I select the last 40 minutes, and Export Selection as MP3 it ends up as something like a 55M file! What's going on? Apparently, it resets the audio format it some way. Why doesn't it just remain as the original mp3 format?
Beacuse as you load audio into an audio editor, it is uncompressed to what basically is wav format. If you don't tell the editor otherwise, it wil be saved uncompressed. In audacity, you use the Export as MP3 function. The MP3 bitrate is set under the File format tab under Preferences, Edit menu.
/Mats -
Thanks. I did some experimenting with SF 8.0 and got the results I needed. Reasonable quality and smaller files.
I think it still is MP3. If it were wave, it would be much larger than that.Originally Posted by solarblast
One possibility is that your original audio was mono, and it was saved out, which would account for a doubling in size. Also, since most sound editors do convert to a uncompressed format while working on it, it will have to be recompressed on saving, which may be at a default compression rate higher than your original.
I lost audio for mp3's, .avi, mpg files, and Audio Switcher::Out
By HartsVideo in forum Software PlayingReplies: 13Last Post: 14th Oct 2012, 20:20 -
MKV files with Audio in DTS need to convert audio to AC3
By THEHNIC in forum AudioReplies: 5Last Post: 3rd Jun 2011, 08:17 -
AC3 (5.1 audio files) and PCM 96/24bit stereo audio files
By joannes in forum Authoring (DVD)Replies: 2Last Post: 9th Mar 2010, 15:48 -
How to combine video with audio file and replace audio with video files ?
By designbuyers in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 11:12 -
How would I create an Audio DVD from my audio files from scratch???
By Hittz in forum AudioReplies: 6Last Post: 10th Jun 2007, 03:15
