whats the best encoder to make vcds (cheers)
Results 1 to 17 of 17
While I am far from a pro, Shit I'm far from amatuer, I can probably say that TMPGEnc is better at encoding mpg1, if that is what you mean. At least from my reading that seems to be the popular opinion. mpg2 it appears would be CCE
L8TR,
WraithBlow me for faster replies....... -
ive used tmpg encoder for a while now but it keeps makin the films stick about every 20 mins or so on my dvd player, used u lead dvd factory and that was ok only stuck once or twice but just wanted some input::cheers
TMPGEnc and Panasonic MPEG Encoder are probably the two best MPEG-1 encoders at standard VCD bitrates and settings.
Regards.Michael Tam
w: Morsels of Evidence -
What is your bitrate? Are you making standard vcds, or Xvcds?
I'm NO pro. But for the price (FREE) TMPEGnc rocks the house for all I do. I make xVCD's with a variable bitrate of 300-2520 with an average of 1444. This puts about an hour on each disc for me...
im just makin standard vcds they keep sticking and going out of sync it gets you down when they are takin 6,7,8,hours to make (cheers)
What method are you using to do your conversion? What are you doing exactly?
Regards.Michael Tam
im using tmpg encoder opening up the file,seeing what frame rate it is then loading the correct template,then selecting full screen and just encoding the movie?????in highest quality
Okay...
What are the settings/specs of your source file? Framerate? Audio codec? etc.
Regards.Michael Tam
here goes dont know if u mean these
size640-366
aspect ratio 1:1(vga)
frame rate 23.796 fpsec
constant bitrate
bitrate1150 -
Okay.
When you encoded your DivX with TMPGEnc, did you load the NTSC-FILM VCD template? Your framerate is 23.976 fps (NTSC-FILM) and so you should choose the NTSC-FILM template.
If you used the standard NTSC VCD template (29.97 fps), then TMPGEnc would have had to do a framerate conversion (which never works out well) can could lead to sync problems...
Furthermore, for encoding DivX sources, it may work better to decode the source audio to uncompressed PCM WAV first...
Regards.Michael Tam
yes ive done that correct i think your right about decoding the audio first(do i need any software for that job thanks)
You should be able to do it with VirtualDub.
Regards.Michael Tam
HDV vs. SD - Pros and Cons
By pooty13901 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 22Last Post: 19th Jan 2009, 07:54 -
which H264 codec do the pros use?
By deadrats in forum Newbie / General discussionsReplies: 4Last Post: 8th Nov 2008, 03:59 -
media pros cons...
By dvnoob in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 18th Aug 2008, 23:07 -
Trying to learn how to encode like the pros,need some help.
By the_joker in forum Video ConversionReplies: 8Last Post: 7th Aug 2008, 10:50 -
Professional Looking Menus for Non-Pros?
By Jeff_NJ in forum Authoring (DVD)Replies: 30Last Post: 1st Jul 2007, 03:03
