Ok,
I have a client who is presenting a speech and he is using the clip from Cool Hand Luke where he eats the eggs. I have the DVD so I thought I could pull the .vob file into my Ulead Video Studio 10 and edit it so that I could use that part. But when I pull the video over about every other second the audio puases and the video is just a little choppy. Is there another program I could use for this that might be better?
Thanks for your help.
Neuz
guns1inger,
This is NTSC.
I am not changing it I am going to keep it as a NTSC.
I just tried VOB2MPG and it appeared to not do anything. I selected the folder containing the VOB files and then gave it a folder to create the MPG to but it appears that it didn't realy do anything.
When I pull the VTS_01_2.vob file over from the DVD to my hard drive and just play the .vob file it works fine. But it just seems to be bad once I run it through my Ulead. Also, the sound doesn't match there mouths.
Thanks for your help,
Neuz -
What does "appears that it didn't realy do anything" mean ? Help us help you
Did you decrypt the DVD with DVDFabDecrypter or similar? You have to do that in order to work with the VOB on your hard drive. http://www.dvdidle.com/free.htm
The other option is to install AnyDVD which will decrypt your VOBs on the fly, so you don't need to rip the DVD to your hard drive. -
Thanks guys I finally got VOB2MPG to work.
Kinda on the same note: taking some VHS tapes to DVD( just about 5-10 minutes) and when I play them on my computer the bottom of the video, just like a line at the bottom, is real staticy. What causes this and is there a way to get rid of it. I've talked to several different people who have experienced the same thing. Any ideas???
Thanks again for all your help.
Rob Neuzel -
It's called head switching noise and you see it on a PC but on a TV you won't as it's in the overscan area. If that's still a problem you can crop it out using a good editing program, not sure if Video Studio does that or not.Originally Posted by neuz"Art is making something out of nothing and selling it." - Frank Zappa
Thanks for the correct terminology "head switching noise ". I never knew what that was called. Ulead does not support cropping. Do you know of any program, prefereably free, that will allow you to crop a video?
thanks,
Neuz
.MTS file sequential playback pauses between files
By Davecom4.6 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 10th Jun 2009, 23:53 -
Capturing Movie clips
By Rockwall567 in forum Capturing and VCRReplies: 1Last Post: 30th May 2008, 22:20 -
Capturing movie from MS-DOS screen mode
By gasumi in forum Capturing and VCRReplies: 3Last Post: 10th May 2008, 08:17 -
add srt file to avi, xvid 700mb movie file
By volam in forum EditingReplies: 2Last Post: 30th Jan 2008, 22:22 -
Converting a Shockwave file (non-movie) to FLV movie
By beyondthegrave in forum Video ConversionReplies: 3Last Post: 22nd Nov 2007, 01:18
