I have this program called I-Doser that lets you listen to sound waves that alter your brain patterns...
The files are .drg and I was just wondering if ANYONE knew how to convert them to mp3 I tried to change the File Extension but they didn't work...
the reason I want them as Mp3's is because I would like to put them on my ipod to listen to them...
Please Help
Google showed no reasonable results but if they can play on a Windows computer, then a sound capturing program like TotalRecorder is sure to work.
How do I set Total Recorder so it makes them Mp3'z and not Wavs??
If you are going to convert, DO NOT use a lossy format like Mp3. Lossy formats throw away a lot of audio, such as soft sounds, certain sequences of sound, etc. For anything that may be dependent on that (e.g. self-help stuff, etc.) this will greatly screw up, if not ruin, the material's functionality, regardless of the compression level.
Convert to WAV, or if you want some compression, a lossless format like FLAC. WAV is universally supported in PCs and is also supported in many MP3 players. Maybe even the iPod. -
Sure, I believe you can import WAVE files into iTunes. Not sure if it'll re-encode them to MP3 or AAC before adding them to the iPod library, though. And, I don't know if third-party programs to work with the iPod allow for WAVE files, either.
So, if you are using iTunes to manage your iPod, it's probably best to just leave them as WAVE files, anyway, unless you don't have a lot of space on your hard drive.If cameras add ten pounds, why would people want to eat them?
Lame MP3 (or any MP3) in Sony Vegas 7
By boom731209 in forum AudioReplies: 7Last Post: 28th Oct 2010, 17:13 -
Trouble converting AVI(divx)+MP3 to FLV+MP3
By BLboy in forum Video ConversionReplies: 7Last Post: 21st Jul 2009, 05:36 -
Mp3 to Mp3? Audio Compresstion / Down sampling?
By YuJay in forum AudioReplies: 7Last Post: 7th Dec 2008, 13:05 -
how to convert MP3 vbr to MP3 cbr?
By sumeshkri in forum AudioReplies: 2Last Post: 26th Aug 2008, 00:59
