Is there a setting I'm missing somewhere or does Virtualdub only work in 4x3 format?
VD doesn't care what your aspect ratio is, it supports most any dimensions. Some codecs have restrictions, though. Divx, for example has the restriction that the width must be a multiple of 4 and the height must be a multiple of 2. Other than that, you can make the video framesize any size you want. However you may want to use somewhat standard aspect ratios to display properly on your TV screen.
From our Glossary:Try opening a widescreen VOB from a DVD with VD Mod, and it will display properly.Aspect Ratio
The width-to-height ratio of an image. A 4:3 aspect ratio means the horizontal size is a third again wider than the vertical size. Standard television ratio is 4:3 (or 1.33:1). Widescreen DVD and HTDV aspect ratio is 16:9 (or 1.78:1). Common film aspect ratios are 1.85:1 and 2.35:1. Aspect ratios normalized to a height of 1 are often abbreviated by leaving off the :1.
VirtualDub will usually only show 720x480 in raw pixel form.
To update the display (preview purposes only) right mouse click on the footage, and select an aspect ratio from the pulldown.
Does the interleaving option in VirtualDub 1.9.11 handle 5.1 sound?
By WebMaximus in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jan 2012, 06:43 -
Recording in 16x9 (Widescreen)
By Gypsy898 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 15th Aug 2009, 14:09 -
16x9 letterbox instead of 16x9 pan and scan
By CogoSWSDS in forum Authoring (DVD)Replies: 4Last Post: 30th Mar 2009, 04:08 -
Anamorphic/16x9 with FAVC
By bgart13 in forum Video ConversionReplies: 6Last Post: 15th Apr 2008, 01:52 -
VirtualDub invalid handle error
By 2manytapes in forum DVD RippingReplies: 0Last Post: 17th Mar 2008, 12:37
