I recorded to AVI and everything is perfect but when I convert this to SVCD using TMPGEnc, the audio goes an octave higher, but at the right speed
any ideas!?
I seperated the audio from the AVI file and encoded to a seperate .mp2 file and multiplexed the SVCD. Then I joined the original SVCD video with the newly encoded .mp2 (which was fine on its own), the audio on the finished file was still an octave higher!
Anonymous49854Guest
Anonymous49854Guest
can I do that with the completed MPEG2 file where the sound is too high?
what program will do that? -
You can do it in TMPG, or many other programs - I'm not sure what you're using now to make the .mp2.
Assuming your original audio is a wav, open TMPG, check 'Audio only', load the wav, select 'Settings' and change the 'Sampling Frequency' to 44.1.
JJ -
Anonymous49854Guest
it is at 44100 :-?
TMPGEnc is what I used to convert the WAV to MP2 in the first place
any other suggestions?
thanks -
What happens when you play the original wav file and the mp2, before muxing them with the video?
Anonymous49854Guest
both the original WAV AND the encoded MP2 are fine on their own
(I used TMPGEnc to convert the wav to mp2)
once you mux them with the video (again with TMPGEnc), everyone's voices suddenly haven't broken yet ;)
thanks for the help! -
Try playing the premuxed video file on its own (change it from mpv to mpg if need be...) and see what the play length is - is it the same as the wav and/or mp2? Whats the frame rate of the original AVI?
If the audio and video play times are the same and the frame rate is 29.97, then I'm kinda stumped.. Have you tried muxing in BBMPG?
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 07:57 -
By SgtPepper23 in forum AudioReplies: 1Last Post: 5th Dec 2009, 21:33 -
Encoding with higher resolution doesn't preserve quality.
By aznstriker92 in forum Video ConversionReplies: 50Last Post: 2nd Oct 2009, 13:38 -
audio encoding: tmgenc dvd author 3 vs. tmpgenc plus
By cL0N31 in forum Newbie / General discussionsReplies: 0Last Post: 6th Jan 2009, 23:25 -
Higher bitrate encoding causes audio sync issues
By keiron in forum Video ConversionReplies: 3Last Post: 12th Jun 2008, 04:37
