Sorry if this sounds like a dumb question
I have looked at the manual here for this recorder http://service.us.panasonic.com/OPERMANPDF/DMRES25-MULTI.pdf
I am wanting to use it with a tv that has a cable box. Will it change the channel on the cable box? I dont understand how it does it as there isn't any transmitter plugin in the back. Do one of the cables in the back force the cable box to change channels.
After the onslaught of insults from this question I will probably have to change my login name.
Thanks for any help...
Do you mean that your TV has a tuner suitable for cable TV signals?
Sam OsbourneBest regards,
Sam Osborne
DVR and Cable Box
By pepegot1 in forum DVB / IPTVReplies: 12Last Post: 27th Oct 2010, 20:33 -
VCRs, cable box, cable mouse, problems
By judybr in forum Newbie / General discussionsReplies: 0Last Post: 2nd Sep 2010, 14:42 -
PC controlling a cable box (USA time warner cable)
By marcolisi in forum Capturing and VCRReplies: 2Last Post: 4th Aug 2010, 17:24 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 13:21 -
panasonic dmr-es25s help
By Hpy68 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 13th Jul 2007, 16:10
