I have a Compro, VideoMate TV Gold Plus (M500) TV Tuner Card. When I first bought it, I had not great video recordings. Couple yeas a go I updated my software and everything improved a lot.
I wiped my drive clean and did a reinstall of my OS. I backed up everything with windows backup but now the drivers are not there.
I went to Compro website, my video card is there on the product page. When I go get the drivers, they don't have any. I've read in other forums compro is no help.
How can I get drivers for my card? I've searched the web but can't find any other place.
Thank you,
Chris.
P.S. If you ever back up your files, use Nero or another burning software, not Windows Back Up. You might not be able to recover it.
Your drivers are available.
do a google search for "VideoMate TV Gold Plus (M500) TV Tuner Card" -
I google searched for hours before I posted. I did it again and did not find ANY updated drivers for my Compro, VideoMate TV Gold Plus (M500).
Kind of hopping someone has them, maybe they could send them to me. If I didn't reformat and saw a post like mine, I would have them in "my downloaded files" folder. -
Its on the compro site ... http://www.comprousa.com/New/en/download.html
You need this one...
2.PCI Tuner card driver
or if your card has fm radio... you need this one
3.ComproFM 2 (Models with FM only)
Altho you should have a driver disk that came supplied with the card when you purchased it. -
I have a driver disc. The drivers on the disc are newer then the link you posted. The video (and other things) improved a lot when I downloaded new drivers. Those drivers are not on the site now. Compro says they do not support my card anymore. Another reason to beleave the drivers on the site are not the ones I need.
Is txt2sup still supported?
By nbi in forum SubtitleReplies: 15Last Post: 12th Mar 2012, 19:18 -
video not supported on lg tv
By zadam123 in forum Video ConversionReplies: 7Last Post: 22nd Feb 2012, 09:50 -
Media Not Supported
By jackowens in forum DVD & Blu-ray PlayersReplies: 7Last Post: 15th May 2011, 00:01 -
Is there a list of all supported files supported by svcd2dvd ?
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Oct 2007, 11:07 -
748x128 is not supported ??
By bigfatbob in forum Video ConversionReplies: 8Last Post: 5th May 2007, 10:28
