    Mar 2007
    Canada
    I'm trying to burn a video onto a cdr with Nero 6.6.0.16 using ISO Data Mode2/XA. It should allow me to burn this video but gives me an error telling me there isn't enough room on the disk for the video. The video size is 712 MB.
    Do I need to change some more settings?
    Feb 2003
    U.S.A.
    Well, let's see...you're trying to fit 712 MB of data onto a disc that's designed to hold a maximum of 700 MB, so why do you think Nero is telling you that you don't have enough room? You might be able to fit the extra 12 MB if you use overburning, but your drive, your media, and your burning software must all support this. Taiyo Yuden CD-R's might have enough overburn capacity. But I don't know if Nero supports overburning and don't know what drive you burning with.
    If you're trying to make a VCD/SVCD, then 712 MB should fit but you need to use the "Make Video CD" template in Nero.
