  1. I have a .OGM video with seperate subtitles. It took me long enough to figure out how to just add the freaking subtitles with VirtualDubMod, so I really need help.
    Step by step, this is what I do when trying to change the .OGM to .AVI...
    First: I open the file in VirtualDubMod
    Second: I then go into "Streams" > "Stream List" (The file is Dual Audio BTW). I then change the default audio from English to Japanese, move the Japanese to the top, and disable the English. (I've tried not disabling it, not moving it, etc.)
    Third: Next I go into "Video" > "Filters" > "Add..." and add my subtitles
    Fourth: I run a "Preview Filtered" to make sure that the audio is the Japanese and that my subtitles are there, which they are
    Fifth: I go to "File" > "Save as..." and choose .AVI. Towards the bottom I choose for the Video Mode "Full Processing Mode" and I choose for Compression "XviD MPEG-4 Codec."
    Last: I hit the save button and hope it works, which it doesn't. The video comes out perfectly, subtitles and all...but I get NO audio, and it makes me kind of angry XD (Note: I've tried other formats of compression but they don't work either...I haven't tried ALL of them...so if it's the compression that I chose wrong, please tell me what to use.)
    If anyone could help me, that would be great.
    Thank you!
    ~Xandal
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    you could just mux the audio into the xvid file when your done - since you have already done the compression
  3. HAHA! That's how to do it I figured it out thanks to you, thanks.
