Are there any drag n drop software programs that work well for dragging files to cd or dvd. I need to save a bunch of files prior to reboot and new install of windows. Thank you.
Thank You,
GolfNut -
it is built in to windows actually - or you can do it with a nero complete install
personally i do not like that driver installed"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
BJ_M to use the windows built in feature do I just right click on the folder and send it to the drive I am burning to? I too have Nero but do not like it for many reasons, have also tried Roxio with no luck.
Thank You,
GolfNut -
Right click on the folder and/or files. Send to the drive. A new icon will appear in the task bar on the right. Click on the icon and follow the directions.
Using drag and drop can produce unreliable discs, be wary. Do a search for packet writing.
Drag nad drop AFAIK has to be supported by the software you are using. -
thecoalman, thanks for the info. So what process would you recommend for backing up files on hard drive to dvd prior to new windows install? Thank you.
Thank You,
GolfNut -
Well if it was me I'd just have to update my backups on my exteranal drive
, backup the most importaant stuff to DVD.
Create a data disc from the regular inteface in your burning application, use write once media.
(Mp4, AACv2, MKV, Webm, Theora) Drag Drop Convert GUI Update v 1.2.0.0
By richter03 in forum Video ConversionReplies: 11Last Post: 21st Apr 2013, 05:35 -
Drag and Drop Assets
By scoooter1 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th May 2011, 04:37 -
AVC H.264 MP4s displayed black by VirtualDub upon drag'n'drop
By bulgom in forum EditingReplies: 22Last Post: 6th Apr 2011, 20:18 -
Drag n Drop Problem
By Jim255 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 29th Mar 2011, 03:26 -
Author tool that allows for drag-n-drop template authoring?
By jlietz in forum Authoring (DVD)Replies: 2Last Post: 16th May 2007, 12:54
