hello, i got small problem with my media player classic. i've been using this software for quite long though, however recently whenever i try to play my video files in full screen, it will resize to original size within 1 or 2 minutes. i did not change any preferences, but i installed some other softwares, i dont know if that's the problem. thx, any help will be very appreciated
What do you have checked and set under Options > Playback > Output? I have Auto-zoom set to 100%, and Change fullscreen resolution unchecked. Those might have a bearing on this, but I'm not sure.
If cameras add ten pounds, why would people want to eat them? -
thank you very much for the reply, why my media player classic dont have such option, or maybe mine is outdated, but i never modified anything in the options. ill try install newer version, hope it works, thx . . . . .
really sorry for double post . . . . . sorry i did not check carefully, because there is also option for output in another tab . . . . . i have options set as yours. and i tried to change various thing in options but it still cant work. . . .
media player classic HELP.
By looseless in forum Software PlayingReplies: 3Last Post: 16th Apr 2012, 19:58 -
Problem using Media Player Classic home cinema player
By True Colors in forum Newbie / General discussionsReplies: 7Last Post: 18th Apr 2010, 08:30 -
Streaming FLV in WM Player or Media Player Classic
By jlz901 in forum Video Streaming DownloadingReplies: 0Last Post: 21st Mar 2010, 12:09 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 23:49 -
Media Player Classic and Windows Media Player 9.0
By siluet in forum Software PlayingReplies: 0Last Post: 26th Dec 2007, 11:01
