  1. Banned
    Sep 2006
    scotland
    i want to add contents in two video_ts folder to a single one and burn it to watch it on a standalone dvd player .. i have no idea how to do it .. especially how to add the .vob ,.ifo,.bop files in two different video_ts folder to one folder .. these are the screenshots of the two folders ..
    help me out
  2. Banned
    Sep 2006
    scotland
    ok thanks for the replies.. its actually camcorder captures.. ..!
    its not that huge in size too .... so do i really need to use dvd shrink ??
    does videohelp have an irc ??
  3. Member kush's Avatar
    Jul 2004
    Near "Pacific Park", USA
    Free, no menus -> just do as linked with DVD Shrink. If both sources are under 4.37GB (4.7 billion bytes; actual # is a bit higher but I digress), Shrink won't need to shrink anything, alternately you can force it to "no compression".
    Not free option -> combine discs with existing menus (while creating a "launch pad" menu to select which "disc" to play), use DVDRemake/Remake Pro. This is my preferred method, especially when considering keeping existing menus. It's well worth the $ IMO. I'm not sure if this is still the case, but VH use to have a deal w/ DimadSoft that got you a discount on Remake if you ordered via affiliate link here.
    I find it (Remake) especially useful for backups of commercial discs, in order to prepare for encoding, ie: ripping out useless cr*p like on-play trailers, disabling unneeded buttons, etc - not something you need to worry about with your particular project I'm sure, but that should give you an idea of it's capabilities.
    [edit] Yes, still there, it's actually through MackemX Software, linked on the DVD Remake tool page:
    https://www.videohelp.com/tools?tool=DVDReMake_Pro
    10% discount on either version - $31.46/$44.96 respectively. There is a demo version, but I don't recall if you can actually export your project in it.
  4. Banned
    Sep 2006
    scotland
    thanks kush ..
    both those video_ts folders are exactly 1.29 gb as u can see from the pic the number of .vob,.ifo,.bup files are different ..
    i have the dvdremake pro is ther a guide on how to use dvdremake pro ??
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
  6. Member kush's Avatar
    Jul 2004
    Try one of the guides here (which likely link to Dimad), alternately there's a number of guides @ Dimadsoft itself.
    [edit] Had a quick look @ Dimad, heres the guide on merging 2 while keeping menus:
    http://www.dimadsoft.com/dvdremakepro/ht_merge_full.php.
    Idiots guide (?) - load 2 projects (each DVD via File -> Import DVD, 2nd disc gets a File -> New Project then Import) -> Tools -> merge DVDs (source 1/disc 1, source 2/disc2) -> Let it do it's quickie job -> File -> Export DVD..Then test once done to make sure it plays as you want before burning.
