thanx very much. The settings look quite complicated compared to TMPGENC XPress.![]()
What is the proper script in AviSynth for that?
Depends on the resolution of the AVI, whether you're encoding for 4:3 or 16:9, and whether or not you want to add black around the outside to account for your TV set's overscan. Here's the FulciLives guide to using FitCD:
https://forum.videohelp.com/viewtopic.php?p=1487285#1487285
Test your .avs in VDub(Mod) before sending to CCE. This is to make sure the .avs is good.
and how to load it onto CCE
To open it in CCE, either drag it into the small box, or right-click the box, click on the "Add" button, and browse to your .avs.
TMPGenc Authoring Works 4 - How do I set the "first button" on a menu?
By silentmachine in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2011, 08:05 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
"Full Screen" button not working properly
By ironjack in forum Newbie / General discussionsReplies: 2Last Post: 14th Aug 2010, 20:20 -
Tried to make a DVDR from "Cinema Paradiso"
By ClaudiuS01 in forum DVD RippingReplies: 4Last Post: 27th Jun 2009, 18:27 -
Set/Fix QuickTime "atoms"/"flags"?
By rumplestiltskin in forum Newbie / General discussionsReplies: 3Last Post: 22nd Sep 2008, 14:07
