hello
i have been using virtualdubmod for several weeks now witrh the huffyuv codec it has been working superbly.then the other day when i clicked on huffuv in the compression window it came up with an error mesage.
The instruction at "0x01901374" referenced memory at '"x00000004".The memory could not be "read".Click on OK to terminate the program
then the program shuts down
can anybody help :(
I've never had VDM crash in that way with several years of use. I also have HuffyUV installed. I suspect something has corrupted either VDM or the HuffyUV codec. I would reinstall both. If that doesn't help, you may have something else running on the computer that is causing a conflict. It could also be other codecs that were installed, or a virus or trojan.
But try it with a different video file first. The video file you are using may be causing the crash.
VD mod hasn't been updated since 2003, so most problems have been thrashed out long ago.
And welcome to our forums.
thankyou for replying redwuz
i reinstalled both virtualdubmod and huffyuv with no luck.I also noticed that even when selecting a different file when i click on the compression window it pauses for a few seconds which it has never done before.I also have the msu lossless codec installed when i select that it work fine. :?:
LG RH2T80 - won't recognise DVD's
By Dalene in forum DVD & Blu-ray RecordersReplies: 3Last Post: 16th Oct 2010, 23:34 -
DVDFab won't recognise DVD
By audax in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2010, 00:16 -
Why won't my computer recognise my films from my camcorder?
By Horseysi in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 18th May 2009, 16:43 -
OS won't recognise harddrives
By mysts in forum ComputerReplies: 6Last Post: 9th Mar 2008, 13:57 -
Vista won't recognise my miniDV cam
By ereiamjh in forum Capturing and VCRReplies: 14Last Post: 23rd Jun 2007, 21:53
