This has me baffled. I'm using Scenalizerlive 4.0 to transfer video to my hdd with a Canopus ADVC 110. I've done this many many times. Recently I reinstalled xp, then installed Scenalizerlive, dv codecs, also installed Virtualdub 1.6 and Vegas Moviestudio trial to test it out.
The problem: when I preview video in Scenalizerlive, the preview window is very dark. In the video "filmstrip" on the right, the video appears to be much brighter like it should be. If i play back the video in Scenalizerlive, it's still dark. If I open the video in Vdub, it's fine. Scenalizerlive did not do this before the reinstall of xp. I'm having a similar issue in Movie studio as well. The preview window of the capture module is fine until I start to actually do the capture, then it goes darker.
My computer specs are in my computer profile.
I installed Scenalizer before installing any codecs. The dark preview window problem was there. I then installed Cedocida DV Codec and the problem remains even after a reboot.
My guess would be that the preview window is using the video card's hardware acceleration and overlay.
Try turning off video hardware acceleration:
Right click on the desktop
Select Properties
Select Settings tab
Click Advanced button
Select Troubleshoot tab
Drag the Hardware Acceleration slider to "Disable all DirectDraw and Direct3D accelerations, as well as....."
Click OK
Click OK
If this helps, then you need to adjust the video overlay settings for your graphics card. (Typically, you can adjust things like brightness, contrast, color etc of the overlay independently of the rest of the display).John Miller -
I fooled around in Nvidia's Television and Video settings, clicked on restore defaults, and that seemed to fix things. I don't know how they got messed up in there, because I never changed anything. Seems to be fixed now.
Unable to play asset in preview window
By gstewart in forum Newbie / General discussionsReplies: 2Last Post: 3rd May 2010, 20:04 -
Vegas Preview Window is choppy--please help!
By duderdude2 in forum EditingReplies: 8Last Post: 24th Mar 2010, 15:29 -
No Video in Preview Window.
By therearenorules in forum Capturing and VCRReplies: 0Last Post: 18th Jan 2009, 15:21 -
preview window plays too fast in various software
By spiritgumm in forum EditingReplies: 4Last Post: 26th Sep 2007, 17:48
