Page 3 of 3
FirstFirst 1 2 3
Results 61 to 76 of 76
    May 2007
    Originally Posted by ChrissyBoy
    What happens if you now process 1080p.hdtv.h264-hv_S2D.mpg on its own?
    Ill try it & let u know m8
    -Dave
    May 2007
    mmmm, the 1080p.hdtv.h264-hv_S2D.mpg file is 0KB in size ? and wont import.
    -Dave
    May 2007
    Hi chrissyboy thanks for the link but when it says input anything over 8 letters it goes nowhere what do i do now
    cheers scott
  4. Could I please also have the link to the V2.5 build?
    I'm still running win98se with .net framework 2.0
    Gealto
  5. i have a idea
    itīs possible to add a option to the preferances where i could change the priority for ffmpeg and svcd2dvd himself?
  6. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    -Dave
    If you re process the original does the S2D.mpg get created and grow?
  7. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    cheers scott
    Any luck?
    May 2007
    Hi no luck here can you help i need to put 8 or more letters but nothing works it just switches off then i have to start it again
    cheers scott
    May 2007
    If you re process the original does the S2D.mpg get created and grow?[/quote]
    no it does not.
    -Dave
    May 2007
    I get this on importing a 52.7MB .ts file.
    clicking on cont... closes the error box window, but the file is not imported.
    -Dave
    May 2007
    [quote="heathen"]I get this on importing a 52.7MB .ts file.
    Update....the file used is (H264+Ac35.1) TS
    -Dave
  12. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    -Dave
    Can you put that file somewhere for me to grab & investigate?
  13. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    cheers scott
    Can you drop me an email & we can try a few things manually?
    May 2007
    Hi where can i email you do you want to send me an email with your address
    cheers scott
  15. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Aug 2005
    united kingdom
    Thanks Chrissyboy, well impressed with the new beta. The encoding speed has improved dramatically
    Do have a few issues though. With the colour scheme it's quite hard to read assets etc., Would just stick to the original or allow user pref. Also, hard a werid problem several times where I couldn't import assets unless I dragged and droppped them? If I tried to import using the menu system they just wouldn't be seen? When I dragged and dropped they were fine.
