I use DVDFab Decrypter then top it off by using DVD shrink to copy my movies and it has worked fine for as long as I can remember. But Lately I've been having some issues! I'm still using the same blank DVD's that have worked for me for years, but after all the typical decrypt/burn process I'm having a horrible playback problem.
I can usually pop the just burnt DVD back into my computer and before playing it it reads it likes its a DVD but when I go to use it in WMP It freezes and then it looks like it loses all its memory cause after the first attempt I can no longer try to view it nor does my computer recognize it as a DVD????
This usually only seems to be happening when burning my TV shows onto dvd. Most movies still work fine. Is there a new software out there I should be using to burn my DVDs? Could my DVD burning be wearing out? Any help would be great!!!
First try other media and see if you get same problem. Or maybe it's just time for a new dvd writer...
Is it possible to Fix AVI problems that have video playback error ?
By TheRandomOne in forum Video ConversionReplies: 3Last Post: 15th Feb 2010, 13:59 -
Strnge video playback error, in-game
By Smells_Like_Feet in forum Newbie / General discussionsReplies: 11Last Post: 23rd Aug 2009, 21:47 -
Playback Error on DVD player..... Process used to work now it doesn't!
By Sisi in forum Authoring (DVD)Replies: 3Last Post: 23rd Feb 2009, 14:07 -
WMP11 Error on .mpg and .mpeg playback
By peebee23 in forum Newbie / General discussionsReplies: 14Last Post: 11th Sep 2007, 14:27 -
Toshiba SD-34VBSB disc error on divx playback - any help please!
By Bonnybarbie in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 14:38
