Hello! I'm wondering if anyone else has any experience with burning these to DVD-ROM for playing on a stand-alone player, a Philips DVP-5960. I've got about nine XviD avi's, whch my player has never had a problem with, but it seems to become confused whenever more than one srt or sub file is included; the first set in the series works fine, but it doesn't seem to recognize any subtitles for any subsequent avi's. I recall the conventional wisdom used to be that you would put an avi with matching subtitle file name in a folder and burn that to a disk, but at the moment, at least, I seem to be getting the best results with putting both an avi and the subtitles (either SubRip -- srt, VobSub -- sub/idx, or SubViewer -- sub) in the root directory of the burned disk.
Does anybody out there know how to avoid this problem with multiple avi's and multiple srt's? I was thinking I might have to put each of the nine avi's and corresponding/matching srt's into a separate folder, and burn the nine folders to the root directory. I could try it and find out, but I'm wondering if there's any glaringly obvious thing that I'm missing here that one of the more experienced members could spot and point out.
Thank you!
I haven't used the 5960, but on my 642's and my Oppo's, I keep all of the files in the root of the disc. Just ensure the movie and sub file(s) are using the same name.
movie 1.avi & movie 1.srt
movie 2.avi & movie 2.sub
...etc.Google is your Friend
Multiple .srt subtitle files in a Divx movie
By sam9s in forum SubtitleReplies: 6Last Post: 13th Feb 2015, 16:34 -
Subtitles: diferent fonts, separate files, interpretable by DVD player
By Ze Tomes in forum SubtitleReplies: 17Last Post: 13th Jul 2010, 21:29 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27 -
.SRT Font Size When Playing Using Flashdisk On Stand-alone DVD Player
By randy3101 in forum SubtitleReplies: 5Last Post: 9th Apr 2010, 01:48 -
How do I name multiple srt files so that the language shows to select?
By JoeBolden in forum SubtitleReplies: 0Last Post: 29th Apr 2009, 14:02
