My apolgizes Scott, I should have started a New Post?, the details of the file have gone to my first post of 07th Feb 2007. Hopefully the moderators can either merge this Post( with the attached file )to the one I just posted/tagged with Feb 07, 2007.
It contained the specs of the movie file viz-
General #0
Complete name : C:\Documents and Settings\Computer\Desktop\Dance Dance - 1CD DVD Rip.XviD - XDB_chunk_1.avi
Format : AVI
Format/Family : RIFF
File size : 1.71 MiB
PlayTime : 34s 166ms
Bit rate : 408 Kbps
StreamSize : 76.3 KiB
Writing library : Boilsoft Joiner build 2411/release
Video #0
Codec : XviD
Codec/Family : MPEG-4
Codec/Info : XviD project
Codec settings/BVOP : Yes
Codec settings/QPel : No
Codec settings/GMC : 0
Codec settings/Matri : Default
Bit rate : 274 Kbps
Width : 720 pixels
Height : 480 pixels
Aspect ratio : 16/9
Frame rate : 30.000 fps
Standard : NTSC
Resolution : 8 bits
Chroma : 4:2:0
Interlacement : Progressive
Bits/(Pixel*Frame) : 0.026
StreamSize : 1.12 MiB
Writing library : XviD0035
Audio #0
Codec : MPEG-2 Audio layer 3
Bit rate : 126 Kbps
Bit rate mode : CBR
Channel(s) : 2 channels
Sampling rate : 24 KHz
Resolution : 16 bits
StreamSize : 526 KiB
The .avi file is attached herewith.
Sorry for the inconv. Brgds
Ashwin
Results 1 to 1 of 1
aspect ratio problem when converting
By ibzomie in forum Video ConversionReplies: 2Last Post: 19th Nov 2011, 15:43 -
Converting .mov to Flash - Can't Maintain Aspect Ratio
By cchrisj in forum Newbie / General discussionsReplies: 2Last Post: 9th Sep 2010, 09:53 -
Need help with aspect ratio woes after rendering/converting
By mpalm887 in forum Video ConversionReplies: 8Last Post: 26th Jan 2010, 02:45 -
Trouble Converting Aspect Ratio *URGENT*
By tyedyetc in forum ffmpegX general discussionReplies: 2Last Post: 12th Feb 2009, 07:32 -
Converting VOBs to xVid with 4:3 aspect ratio?
By AOBCD8663 in forum Video ConversionReplies: 2Last Post: 18th May 2008, 20:31
