I have a DVD with a 31-second motion menu that I complied with TDA 1.6. This DVD also has a 20-second intro clip that plays at startup that I added using PGCEdit's import first play clip function. Is it possbile using PGCEdit or some other freeware/shareware app to modify the motion menu to timeout after so many loops (e.g., 6 x 31-seconds = ~3min) and play a title? If so, what about timing out to a stop?
Yes, you just need to use a conditional post command. I don't have/use TDA myself, but I think the loop command will be there (post command of the VMGM menu). Use a free GPRM register (pcgedit can find one for you) and add 1 to this register each time the loop is done. Add a condition like: if GRPMXX > 6 jump title YY. In the pre command of the title reset the GPRMXX register to 0 again.
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
I accomplished the menu timeout using PGCEdit. Specifically, what I did was to author a DVD in TDA v 1.6 with motion menus. I authored the DVD with a main menu and multiple tracks only (no track menus). Each track contained one epsiode. The result was a motion menu that looped every 31-seconds. I then use PGCEdit to cause the motion menu to timeout after 6-loops (~3min) and play all.
If it would be of benefit to anyone, I'd be happy to put a short guide together describing what I did. Any interest?
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
How can I use an existing motion menu, on a newly created dvd?
By Denvers Dawgs in forum Authoring (DVD)Replies: 13Last Post: 23rd Jun 2009, 16:09 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 12:01 -
TDA 1.6 menu help
By colt4523 in forum Authoring (DVD)Replies: 0Last Post: 3rd Nov 2007, 19:46 -
How Do I Put A Custom, Created Slow Motion Clip Back In? (Virtualdub)
By WishMaker in forum EditingReplies: 8Last Post: 24th Oct 2007, 12:14
