  1. Member SE14man's Avatar
    Jul 2005
    Queensland
    I am getting all kinds of egg bacon and bubble with my ip address.
    I think i have a dynamic IP.
    I am with an ISP in Australia called 'Eftel'
    I go onto the command promt and type ipconfig to get this:
    IP Address: 10.1.1.2
    Subnet Mask: 255.0.0.0
    Default Gateway 10.1.1.1
    It doesnt seem to hsow a real IP address therefore if i go onto www.whatismyip.com it tells me my external one is 205.xxx.xxx.xxx etc.
    This is preenting p2p/ftp software working properly for me (i think)
    How do i solve this issue?
    Cheers!
  2. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    IP 10. is not an Internet accessible address. You are behind a router /firewall that provides network translation. This by itself should not restrict you from using p2p or ftp, but if the router is set to block certain ports it could cause your problems. If the router is not yours, then you will have to contact the provider to open the ports.
    Buy My Books
  3. Member SE14man's Avatar
    Jul 2005
    Queensland
    i htink this is issues with firewalls cos im pretty sure this thing isnt linked up to a router however i iwll double check that now.
    im using the windows firewall any ideas how i cld make it work?
    for example with a p2p program called emule the arrows shd be green but theyre always yellow which is known as a 'low id' dont understand any of it!
    cheers mate!
  4. Member SE14man's Avatar
    Jul 2005
    Queensland
    ok i am beihnd router it turns out.
    would you have any idea what port number DC++ would use?
    and emule?
    cheers!
  5. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    Sorry, can't help you there. I don't use any p2p software.
    Buy My Books
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    This site will probably cover more than you wanted to know about port forwarding.
    http://portforward.com/
    Read my blog here.
  7. I am with an ISP in Australia called 'Eftel'
    ur having a laff surely?? whats all that abaht then?
    The electronic components of the power part adopted a lot of Rubycons.
