  1. Member Bronx's Avatar
    Dec 2003
    Bronx, New York
    Can someone explain how to use this two pieces of software.
    I recorded a TV show on a standalone DVD recorder. I imported the mpeg file to the pc. Then I draged the
    mpeg file to comskip. Comskip analyzed it and produced 3 text documents.
    My question is how to I use Cutterman after I run the mpeg file through Comskip.
    Thanks.
    When it sounds too good to be true, it usually is!!
  2. Member steveryan's Avatar
    Jan 2003
    Manchester
    Open the .ini file, find this line - output_cuttermaran=0 change the 0 to 1. Comskip will now create a .cpf file that can be loaded into
    Cuttermaran.
    http://home.hccnet.nl/g.van.schaik/pe-mpeg_editing_cuttermaran.pdf
    He's a liar and a murderer, and I say that with all due respect.
  3. Member Bronx's Avatar
    Dec 2003
    Bronx, New York
    Thank you so much. That was exactly what I needed.
