    Feb 2007
    Everytime I tried to convert a video into an MPEG02...
    The Sound is always off...Do you know of ANY Programs to convert the Video from RMVB to MPEG02 or AVI...
    Without having to edit the sound with virtualDub manually??
    Please reply
    USA
    RMVB to any other format can be difficult. The problem is the 'VB' part; 'Variable Bitrate'. That makes it difficult for most encoders to properly read the length of the video and audio. And the results are often out of sync. Probably best is to separate out the audio and convert it separately from the video.
    Here's one guide: https://forum.videohelp.com/viewtopic.php?t=284288
    And a thread for some different methods: https://forum.videohelp.com/viewtopic.php?p=987885#987885
    Three encoders that might work: TMPGEnc, SUPER, ConvertXToDVD.
    Jul 2006
    Mexico
    i was having trouble. too, finding an easy and good converter. then i found "allok rm rmvb to avi mpeg dvd converter". i tested it. seems to work great. give it a whirl. message me if you have any questions.
    here's the site address:
    http://www.avi-converter.net/rm_rmvb_to_avi_mpeg_dvd_converter.html
  4. I used this guide:
    https://forum.videohelp.com/viewtopic.php?t=212204
    to convert to an XVid avi file. It runs fine on the computer, but has no audio on a DVD player.
