I'm not exactly sure what I have to tell you the truth but, I have downloaded a couple documentary's that I beleieve are AVI's in divx codec .. ? I've tried converting these using WINAVI and it does convert them but when I try to burn the files I get errors using a couple of different burning programs.
What is the best way to determine exactly what my downloads actually are and the best way to finally burn them onto DVD?
what errors? what burning programs?
ANd I would use ConvertXtoDVD or DVD FLick instead of winavi. -
Well, after I converted the download (windows sees its an AVI, with the Divx codec) I get the DVD_01_1 directory that holds 2 sub directories containing directories AUDIO_TS and VIDEO_TS
VIDEO_TS folder contains:
VIDEO_TS (Backup File of the IFO) 8 KB
VIDEO_TS (DVD Movie Info) 8 KB
VTS_01_0 (Backup File of the IFO) 74 KB
VTS_01_1 (DVD Movie Info) 74 KB
VTS_01_1 (DVD Movie) 4813858 KB
I tried to use Clonve DVD 2 using the "Write Existing Data" function and I also tried to use the write function in WINAVI but bothe gave me "unexpected error" and neither elaborated on what exactly the error was. I tried using DVD Shrink, but it just wouldn't even recognize my converted files. I'm wondering if I donverted incorrectly or am just simply missing something here. I've done a fe converts and curns but I'm far from a pro at this. Thanks for your help with this. If the above looks like I did most everything right, I'll try your suggestion and convert it with ConvertXtoDVD. -
If you have access to a mac Toast 7 & 8 do a nice job converting avi/divx files to DVD. Both in 3:4 , 16:9 and with DD or PCM audio.
Cheers,
PMPaul May
Spotmen Studios Inc.
15 N. Arlington Heights Rd.
Suite #103
Arlington Heights, IL. 60004
spotmen.com
http://spotmen.com/search/spotmen.html
Converting DVD to AVI...but to DivX, MPEG4, YUV or XVid??
By lnong in forum DVD RippingReplies: 1Last Post: 11th Oct 2009, 07:44 -
Converting DIVX .AVI Files to DVD using Nero Vision 8 and 9.
By nnhood in forum Authoring (DVD)Replies: 2Last Post: 26th Jun 2009, 20:09 -
Converting a Home DVD to AVI - but not divx?
By sterankin in forum Video ConversionReplies: 4Last Post: 16th Feb 2008, 12:52 -
best software for converting dvd to avi, divx etc ???
By geronemo in forum Newbie / General discussionsReplies: 4Last Post: 15th Nov 2007, 13:48 -
converting .avi (divx) to dvd and keeping original quality...
By RushMaster in forum Authoring (DVD)Replies: 15Last Post: 22nd May 2007, 15:47
