I have been using Nero Vision 4.7.0.7 for a while now. Every now and then the resultant DVD has sound sync issues. Normally not a real issue (to me) but sometimes annoying.
I have been reading these forums recently and have come across a number of other people that seem to be having similar issues, and a number of reponses that explain that usually the problem is probobaly CBR vs. VBR.
I understand this, but don't particularly want to go down the alternative routes that have been suggested.
Please can anyone recommend a suitable alternative application.
It needs to be;
¤ Simple and easy to use (GUI rather than command line)
¤ Able to manage very basic menus (like Nero)
¤ Have beeter sucess with sound synch on its output
¤ Able to manage a number of different sources files per DVD
It doesnt need to be;
¤ Fast (I leave it going overnight, or when i go to work)
And ideally it would be free, or at least low cost.
Any ideas?
Thanks in advance
ConvertXToDVD handles most VBR, but I still save out the audio as a WAV with VDM if I see VBR, then I don't have any surprises with sync issues if ConvertX fails.
Great tool ConvertXToDVD
Free: AVI2DVD [for conversion using HCEnc]+ImgBurn [For burning]
If I remember correctly it does everything that you have asked for.আমি বাংলায় গান গাই
mkv to avi with xvid4psp! It's killing me! Help pls!
By Ramazan in forum Video ConversionReplies: 1Last Post: 28th Sep 2011, 08:52 -
Pls Help convert my 3gp file to mpg or avi
By Nanflexal in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 16:58 -
pls or m3u to avi
By py52126 in forum Video ConversionReplies: 1Last Post: 20th Jan 2009, 15:35 -
mkv to avi , help pls
By a_n00b in forum Video ConversionReplies: 3Last Post: 4th Jan 2008, 05:17 -
How to make a sample of an AVI file pls?
By incrediblej in forum EditingReplies: 5Last Post: 20th Dec 2007, 08:59
