I have hundreds of avi's and I want to process them in a batch. All of them are 640x480 XVid avi's @ 29,97. I know how to remove audio streams in VirtualDub, but I don't want to spend the next 3 years editing them one by one. Is there a way to script the whole thing?
P.S. I don't know if I posted this in the correct forum![]()
What exactly do you want to do?
What is the goal?
Do you want to extract the audio only?
Convert it?
Or when you say 'remove' do you actually mean you'd like to be left with video only avis?
River past audio converter is probably the easiest thing if conversion is a factror as you can drag
and drop avis directly and set a common output target. It should also work with simple audio extraction as well, for most things. Certainly will with mp3.
There's also nothing wrong with using the vdub job control. It takes well under a minute to set up each file. Not very long even when you've got hundreds of files + a level of independent control depending on what you are doing.
You could also seperate the files according to the audio contained. A directory for each type.
Download ffmpeg.
Put it in each directory (for ease).
Create a batch file for each with the following code (changing 'mp3' to the correct extension for each type)
Run batch in each directory.Code:FOR %%A IN (*.avi) DO (ffmpeg -i "%%A" -acodec copy -vn "%%A.mp3" >nul)
For avis without audio, in case that's what you want.Code:FOR %%A IN (*.avi) DO (ffmpeg -i "%%A" -vcodec copy -an "%%A.avi" >nul)
I want to remove the audio completely, so River Past is out of the question. Each avi has a single mp3 stream @ 128 kbps. VDub has script support, how can I use it? I know how to do a few things in that program, but unfortunately I have no idea about scripts. All I know is that I can save processing settings with Ctrl + S. I've never used ffmpeg so I have no idea what you're talking about
45tripp's suggestion to use ffmpeg is a good one....
Copy the 2 files in this zip into the same folder as your AVIs. Double click Demux_video.bat to start. Output files will have a V- in front of the name.
demux_video.zip
Machete 3.7 is released - edit video files with multiple audio streams
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 17th May 2011, 14:54 -
How to join AVI files with multiple audio streams
By V@no in forum Newbie / General discussionsReplies: 2Last Post: 29th May 2010, 23:17 -
Streams with Multiple Files
By topquark in forum Newbie / General discussionsReplies: 1Last Post: 24th Apr 2010, 07:31 -
Play multiple streams in DVD (Merge multiple streams)
By sebastien91 in forum SubtitleReplies: 0Last Post: 25th Apr 2009, 19:44 -
Removing certain audio streams/subtitles from a DVD
By SiM99 in forum DVD RippingReplies: 18Last Post: 7th Feb 2009, 02:46
