  1. please help- cannot figure it out !
    I just want to apply virtualdub filter to a portion of my video- either avi or mpeg, but not the whole clip. then I want to save it- but virtualdub either applies to the whole clip or seperates out the selected clip and just save thst small section.
    how do I use a filter on a selection of a clip and then recombine my whole clip ?
    thanks-
    sammywoof
  2. moin, moin,sammywoof
    > clip ?
    I don't know I directly way, too,
    but a way that will work.
    1. Split in 3 pieces
    2. perform on the 2. piece
    3. join pieces.
    after splitting, you can make a batch
    to do the rest.
    bis denne...
    scholly
