  1. ok i am making myself some movies and i want to know a quick and easy authoring program for .vob files where i can make menus with backgrounds and music. I also want to have one that does not reconvert. I used Ulead DVD movie factory 2.0 and it was working fine and not reconverting until the other night it kept saying there was an unspecified error when i tried to burn a movie. the program i use to convert is convertxtodvd. if any one can help that would be great also if they know why there was an error.
    Apr 2004
    Miskatonic U
    TDA
    Read my blog here.
    SVCD2DVD.
    Ignore the fact that it says "SVCD". It's a really good authoring program that accepts non-standard resolutions too (hence the niche name). And the author is a videohelp.com member.
    TDA is good, but it's various defects make it less attractive than SVCD2DVD, which can do most everything (authoring-wise) that TDA can do, and a few more things. SVCD2DVD is just as easy, costs about the same, and outputs more stable menus.
